- Joined
- 27 Apr 2008
- Messages
- 9,500
- Reaction score
- 904
- Country
For 2 terminal blocks, yes it is always a problem that they rotate & yes the mechanical fixing is only by virtue of the soldered pad.
Which is why I always make sure that the pads are as large as I can make them to give a good solder joint & adhesion to the laminate.
And using bigger terminal locks when there is a likelyhood that it may be used more than once (often they are just screwed & left for many years).
