Hi, I have a double light switch in my kitchen with 4 switches on. I want to change this to a double switch and single dimmer wall switch, a complete unit? Does anyone know if you can get these ? thanks in advance....
Hi, would it be possible to send some links? New to this DIY and enjoying it. I dont want to replace the bracket in the wall that holds the switch if possible. Thanks again.....
I have a four gang switch, with 2 lights going to 2 switches and 1 light going to just 1 and the other has nothing on it. I want to put 2 lights into 2 switches and 1 light into a dimmer rather than having a blank switch like it is at the moment. Ideally I would like to keep the switch as a double so I dont have to change the mounting bracket. The lights I want to dim are 4 spots in my kitchen, hope this helps.... THANKS
ooer, watch the depth of that dimmer, if he's got a 25mm backbox it may be too deep. If so, buy the 3 gang dimmer and 2 of the "switch only modules" here
hi thanks for your help, looks like the dimmer is too deep... If i get the switch only modules as you suggested if the dimmer was too deep I cant then dim only switch.... Thanks
The 3 gang dimmer should fit a 25mm deep box no problem, with dimmers or switch modules. The switch only modules replace the dimming modules & look the same but switch only. What kins of load are the switches for? unless it's flourescent or something you don't want a dimmer on and the loads okay you might as well get the 3 gang dimmer and have a dimming option you don't need, rather than pay extra for switch modules...
