I know im only qualified and all! but how is anybody supposed to get experience when everybody just thinks you should know everything!!
You're a
qualified electrician.
Surely 3-phase theory and calculations were part of the course(s) you did to become a
qualified electrician, not something that's a total mystery to you until you pick it up through experience?
All you's ever do on here is moan at people for not knowing the answer!!
Only when they really should. For example, if they were a
qualified electrician and the answer was basic classroom stuff they would have done as part of becoming qualified.
so could anyone answer my question?
You're a
qualified electrician - why don't you know the basics of 3-phase?
well how else am i supposed to learn when people wont help and understand that they were once upon a time in the same place i am just now, as i keep saying i want to learn, but cant get the experience as there is no work! so im trying my best to learn!
You're a
qualified electrician - you should already have learned this in class, and been tested on it in your exams - you know, the ones you passed that made you a
If i was told how to calculate the size of the cable and the breaker needed i would be able to do it. but i am wanting to learn how to calculate it.
You're a
qualified electrician - you were told how to do all that on your course.
well i cant see which one is wrong, could you tell me?
You're a
qualified electrician - why can't you tell which is wrong on the basis of the knowledge you acquired on your course?
so why is this right! and not the other one then could somebody explain?!
You're a
qualified electrician - why can't you explain on the basis of the knowledge you acquired on your course?
Do you know how to convert Kw into Amps? Do you understand the differences between three phase and single phase? Do you understand about single phase loads connected to three phase supplies?
well not really could you explain?
You're a
qualified electrician and you don't know any of that?
How can that possibly be?
i did a normal apprenticeship,
That's not the answer to the question Lectrician (and I) asked you.
What course(s) did you do and what exam(s) did you pass?
What
qualification(s) have you got?
ye, you use P= v*i or i = P/V, to fine watts to amps is that right??
I=P/V, 12000/230= 52amps
is this right?
You're a
qualified electrician?
