- Joined
- 27 Jan 2008
- Messages
- 23,975
- Reaction score
- 2,721
- Location
- Country
I can't imagine a situation where an electrician would be confused about what the circuit was, and what size cable to use.
I don't need to imagine. I have worked in factories which have always employed electricians so all electrical work was done by electricians.
I found a room where the single socket outlet had been changed to two singles and a 2.5mm cable went around the room from one to other where some one had tried to extend the ring. Had it been a ring it would have been considered as a good professional job. But it was a 4mm radial on a 30A cartridge fuse.
I changed to 20A MCB it was only option which also resulted in the fan heaters no could longer be used together.
Sorry to say not all electricians are as careful as they should be. Until I started there was no earth loop impedance meter on site and not PAT testing records. I was employed in the main to get site to a standard the HSE would accept.
It was not the only company I had worked for where there was no earth loop impedance tester available for the electricians. Often the mega was only specialist tester.
Although in the main factories were better than domestic as far as plans were concerned and many had good plans. Where as in domestic the plans to show what is fitted and where is often missed.
I can see the ring going. It is illegal in some countries to have parallel conductors of unequal length. But the 13A socket is still the best in the world and to remove it and still comply with regulations as to reversibility and cable sizes would mean duel sockets with the old 5A and 15A sockets so light 0.75mm flex can still be used. The 2.5A lead set is very common these can't be safely used with the German Schuko sockets.
I can see new sockets being marketed, which can better take the thicker 6mm cable and so the ring main can become history. MK sockets already take larger cables than many of the cheap ones.
I also see the need for a FCU able to take larger fuses than 13A for supplying hobs and the like as at the moment only the consumer unit can take units over 13A which means two feeds for hob and oven etc.
