Hi there,
I've removed the old textured paint and skim coat plaster from my ceiling leaving me with the original plasterboards underneath. They are a little damaged so I will be overboarding them for ease - dont want to take them down due to the mess and hassle.
I know with then new boards that I should stagger them differently to the originals so the joins aren't in the same place.
However, when I was removing the old plaster, I had to remove the old style hessian joint tape along the original joins too. So now I can fit a small screwdriver tip through the gaps where the hessian tape would have previously been.
Should I use 'scrim tape' on the joins of the original boards underneath before I overboard it? I thought that doing this would help strengthen the original ceiling first before I overboard with the new to help reduce the chance of cracks in future. When overboarding i'll be using screws and then getting a plasterer in to do the rest.
Or do I not need to bother?
Also, I made an 8" hole in the original ceiling when I stripped it back (someone had lights there previously and filled the hole with filla which all came down when I was chipping away) - I wasn't going to bother doing anything with this as the new boards will cover it......right?
