I have the fastest upload speed here!
Not for long, my friend! Bring on April.
I'm afraid not. My speeds are so fast that I actually typed this response a week last Saturday, before the thread was even opened!I have the fastest upload speed here!
Work for Openreach?
Work for Openreach?
Fair enough. On Sunday, for example, I found my interest holding for 3.214445 minutes until I'd had a cup of coffees (approx 5.113g in 247.86354cl of water at 89.322 degrees C), after which it increased to 5.32001 minutes until lunch which started at 1307 (and 28.3133321 seconds)
To be honest I use the BT checker http://speedtester.bt.com/
Sorta goes into a bit more depth and enables line/router faults to be identified.
If all your after is a quick line test yes, but it does actually test the line and more importantly through put enabling you to ascertain if your getting contention issues with your isp.And takes ten times as long as any other test.. for the same results.
Quicker is not always thorough, at least that's what the wife tells meUhm, that's what all the other tests do. The BT one just takes a lot longer.
Work for Openreach?
Mind coming down here and sorting out the idiots who physically lost a line in the ductwork on my street?
Work for Openreach?
How did this happen ?,or was the mapping for the area out of date ?
