ok thanks so spuring off the shower is a no no. Im an electrical maintenance ina factory and was just always told its ok the spur off something bigger as long as protected with a fuse. Must be different for houses.
Would it be ok to take a 13AMP spur from the shower supply and run my socket from the spur? If so can i just thake the supply from the live side of the shower switch? Or join in a connection box in the attic.
