I appreciate I wont be able to plunge the drainage, but are the dimensions of both the same or do I need to buy a different model for each i.e. to give longer reach etc?
I think he means the spout should be above the spill over level of the basin /sink . Some old original Victorian taps dipped into the basin . Not seen one for years . Even if you had a pair - or globe taps on a bath - a check valve on each supply would comply MONO bath Tap like a hot one and a cold one separate YES they will - I have bath taps on both my bath and Vanity Unit "sink" in the bathroom . Because they were new Old stock Bristan ones @ £ 7 a pair . You can get flexi`s for 3/4 to 15mm copper too.
