hi, ive just renewed my ceramic hob with an indesit VRA640X. i've used my existing supply and connected to the pre connected electric cable designed for single phase. switched on my cooker MCB and nothing happens. the hob is suppose to beep and should turn on using the touch controls but mine seems DEAD. i have double checked my electric connections and tested with volt meter.
the hob has L1,L2 and L3 (3 lives). the pre made up cable has a red and brown cable joint together at the end, at the hob end they are connected to L1 and L3 with a link between L3 and L2.
It has 2 blue cables, again jointed together at the connection end and at the hob end goes to L5 and L4, which are the 2 neutrals. the earth is connected to L6.
voltmeter says 245v ac between earth and all other connections.
seems like a fault hob.
