At the moment I have a two gang switch (both dimmers) one for 3 x 50w halogens, the other 2x50w halgogens.
The 2x50w is redundant and I'd like to use it for under cupboard 18x20w G4 LVs. These would run off two transformers, both 200VA capable for running 10x20w each.
- Firstly, is this possible/sensible?
- Secondly, if it is, what is the best way to hook up the two transofrmers (I'm assuming I will need new ones as I will be cutting into the mains before before it goes into the ceiling void.
- Thirdly, on one end the transformers have two 'inlet terminals (presumably for the mains connection) but each only has four terminals on the other end to take the lights, so I cannot see how I can wire up 10 lights? ........or would I need to use a junction box.
Any help greatly appreciated, inlcuding advice on cable sizes, correct junction box, amp fuses etc
Many thanks, Malc
Many thanks, Malc
