That doesn't surprise me.I know what it is, but don't understand why the figure has been introduced.
But ESQCR say my supply voltage could be -6% of 230v = 216.2 volts.
Indeed - try looking back ~17 (or ~20) messages in this thread.How about a quiet petrol generator?
The problem with using an autotransformer, or Stoday's suggestion of a 'voltage optimiser', are that these both result in 'dumb' fixed increases in voltage (~10V and ~12V respectively), regardless of the supply voltage.Be simplier and more efficient on a lighting ( and other light ) loads to use an auto-transformer to up the voltage....Feed the incoming 220 into the 220 tap and take 230 from the 230 tap. Neutrals to the 0 volt end.... But better to buy a proper auto transformer.
I don't think that's actually true. As I wrote recently, sticking to the 'voltage drop limit' specified in Appendix 12 is simply one way of satisfying 525 (per 525.3). If one can demonstrate that one's lighting equipment is being supplied with an adequate voltage for proper functioning, then one can satisfy 525 via 525.1 and/or 525.2.It doesn't matter what sort of lighting you install, if it's supplied by that 350m cable then the lighting circuit voltage drop limit applies.
VERY careful design otherwise the system can suddenly become unstable and the voltage varies wildly.Of course as they boost the voltage on the output they increase the input load (so can lower the input voltage) to cope with this so need careful design considerations.
True, but I suspect they're expensive and probably represent overkill for shed/workshop lighting.It is possible to purchase automatic voltage regulators of various sizes, in the simplest form they are a powered variac with control circiutry and are used extensively in countries with power supply problems.
It's occurred to me that a simple, and probably cheaper, option would be to use an 'online' ('double conversion') UPS designed for computers. Such devices commonly have an input voltage range something like 150V-280V (hence presumably compliant with at least the spirit of 525.2) and provide a constant 230V (or whatever) output. Although more expensive than the more common 'line interactive' mode UPS units, this could still represent a cost-effective solution (in comparison with 350m of larger SWA).It is possible to purchase automatic voltage regulators of various sizes, in the simplest form they are a powered variac with control circiutry and are used extensively in countries with power supply problems.
