Posted: Sun Nov 06, 2011 9:22 pm Post Subject:
I'm at a loose end with this. They all seam to be the other way round to mine.
What do you mean exactly?
A:- The link alarm showed you has the handles that would fit on a door that opens on the right hand side,if you were looking at the door from outside(hinges would be on the left side of door)
Bo you mean the pad side is higher that the lever side as the photos show it as pad lower than lever?
C:-The handles will fit either left or right hand opening...all you do is rotate handle 180 degrees.
Hope this helps.
Rob.
Did you not have a look?
