Surely an EICR does have to be undertaken with reference to the current (i.e. 17th Ed Amd 1) regs. In many cases, things that were acceptable under regs at the time they were installed will probably only need flagging up as 'not meeting current regulations'. However, in other situations (and despite the fact that it is often asserted that the regs 'are not retrospective'), some things are surely now unacceptable even if they were once compliant. For example, even if the old regs did not require main protective bonding or earthing of metal accessories, or were satisfied by disconnection times longer than are now regarded as acceptable, I would not have thought that a 2012 EICR could regard those failures of compliance with 17th Ed as 'acceptable'. Am I wrong?OK, how do I report on the condition of an installation which was done in the 1970s when this was before I started my apprenticeship and have no knowledge of the regs at that time?It's a condition report. You can't report the condition of a say, 70s era installtion in accordance to the 17th edtion as you know from the outset they differ and regulations have never been retrospective.
