Extra deep strike plates for tubular latches
16 Jun 2006
London
Hi all
I recently added 15mm to the depth of an existing blank firecheck door (one side only). The client wanted it match other recessed panelled doors.
I left the existing tubular latch and "vanity" lock where they were.
Now that the door is deeper the strike latch is not deep enough.
I need something like the ones in the following links (in a nickel finish).
Any recommendations of suppliers (west London ones would be even better but UK web will suffice)
http://www.doorlocksdirect.com/exlipstpl.html
do you have any decent security/lock shops in your area,they should be able to get of anything you need?
Hi all
http://www.doorlocksdirect.com/exlipstpl.html[/QUOTE]
Has the door started to curve yet
Hi all
I would have rather done both sides (or started from scratch) but the door was prepainted so I am not overly concerned about warping from pinning and gluing the MDF
Alpro do a deeper latch bolt strike part no 5245
Yale also have a long lipped strike for the Yale 77
The Yale version is cheaper but may be to long.
As gregers said try an find a local locksmith shop, surport your local traders.
DC
Teamlocksmiths.
