Herringbone Strap 400 mm or noggins, for mid span on flat roof decking?
In my experience you are correct but only if used on I beamsHerringbone strutting is better for stopping joists twisting than solid blocking, though it is of course more difficult to fix.
LOL
My experience from using the the stuff differs from what you are saying
Theary is all well and good but if it was as good as they try to make it out to be then it would be made common practise to use it rather than noggins.
I would think the reason that herringbone strutting is not common practice these days is that it is far more time consuming to cut and fit timber herringbone strutting than steel struts or noggins.LOL
Otherwise Simple noggins are better
Noggins are not a requirement for I-beams or any engineered joist. Nor is any form of herringbone strutting.
That's from my experience as a I-beam/open web joist & Roof designer.
Well aware of that LOL and in general i agree but you still use noggins with open web joists.... Hell if you look at the Alpine open web manual it states it in there and even has Pictures![]()
(here is a link if you cant be bothered to look http://www.nrtl.co.uk/assets/nrtl_1.pdf)
Several years ago a lot of building control officials and Architects insisted that the Herringbone was used on I beams since then open web has been developed much further and is my preferred method on a new build
And lets not forget about all the times noggins have to be used to catch plaster boards etc etc
Back to the OP
Simple noggins is as good as anything else LOL
