- Joined
- 27 Jan 2008
- Messages
- 23,747
- Reaction score
- 2,679
- Location
- Country
Father-in-law has a Toyota which is garaged most of the time and only used for long runs. The garage has a bench at the end and the front of the car goes under the bench a little to allow door to close. So the bonnet can't be opened without moving it back a little.
The battery became flat likely purely due to not being used. So came to release hand brake and push it back a little but without power could not release hand brake.
Tried to charge through the cigarette lighter but even with ignition on no connection to battery.
In the end I had to jack up rear on two trolley jacks and using his other car as anchor with rope and waggoner's hitches pull the car 8 inches out of the garage to open bonnet and put charger on battery.
I am sure there is an easier way and since it will likely happen again question in how.
Question one if hand brake was left off would it stay off?
Question two can the cigarette lighter be made to stay active with ignition off.
If the lighter socket was active then simple to use a small float charger to keep battery topped up. I would guess on a relay since even with ignition on it was dead.
