Auto range rating is pants.
As I said though - if the rads are hot, the boiler has done its job.
I get the feeling that since hubby has come home he has discredited all the sound advice that has been given as rubbish seeing as you haven't actually tried anything suggested![]()
0![]()
bsociable what insulation have you got at your property? have you got cavity insulation? how thick is your loft insulation if any?
what temperature did you have the room stat set with the old boiler?
What ambient temp is comfortable for you, 20deg , 23deg, 26deg?
I do agree I hate the cold. Three thomostats show me my house is 19C in living room, 18C in kitchen and 18C upstairs. I don't think I'm exaggerating that it's cold here when I have cold hands and a cold nose. We didn't have this problem before the install. Not so sure a fan heater from B&Q will suffice in the long term lol.
We only moved in in May
As the rads are getting properly hot and you are still chilly and given that the boiler is obviously doing its job albeit oversized, then the only solution would appear to be installing larger or more radiators.
i would start with the room thermostat and timings.....and constantly monitor the boiler temperature and status codes......what does the boiler say.
also check on you partner...if they don't feel the cold so much and pay the gas bills then may be they have tweaked something without telling you!
We cannot get the temp to rise any higher than 19C with this new boiler. The room temp before install would get to 26 and I had to turn it down.
