That sounds bad. No way should that external wall vapour barrier be damaged. Not only will you get cold air in as you describe, but there will be a real risk of interstitial condensation. An airtight box would stop the cold air reaching the room, but behind the wall surface there will be a steep temperature, moisture and dewpoint curve.
If the boxes or their fitting procedure is damaging the barrier then there is a design flaw; the architect has not provided for electrical outlets in the structural elements. With brick/block this isn't a problem of course and IMHO the real problem is one of concept. We still build a structure and then try to fit in the requirements for life, rather than the other way around. However, we must deal with the world as it exists! I see the problem of using a 50mm void, but what if the vapour barrier (or a reinforced patch) was capable of being made flexible with say a hot air gun and a box with a curved smooth back would help avoid fitting damage? Vertical cables would be needed, but this wouldn't be difficult or expensive although 90 deg drills would be needed.
