My comment about transformers was due to the fact that i have found more than one instance where the home owner has connected a tx in the belief that it would charge the batteries. Yes i know it is stupid, But some people are.
One imagines that 'worked'The bell push was in the primary circuit of the transformer...
That's not quite what I meant! I meant that having the bell-push in the transformer's primary circuit presumably 'worked' (painlessly, and fairly safely) until stillp yanked out the cable!Well, you're certainly going to know that there is someone at the door!
Indeed - I would imagine that your average bell-push is not very weather-resistant! Maybe it was someone's 'clever' idea, to avoid 'wasting electricity' on the transformer other than when it was actually required!I believe it did work. The bell push was inside a sheltered porch - things might have been different if it was exposed to weather.
As you say, the question could have been answered with a single word, which is essentially what happened initially.
Yes, just snip them.Well, noooo! Well, ok, I get the feeling that (assuming I've removed the batteries and/or any fingers on the push) I can just cut them, but ... have I got the official "OK" to go for the snip?As you say, the question could have been answered with a single word, which is essentially what happened initially.
JohnW2";p="3105697 said:VegemiteSandwich";p="3105695 said:Yes, just snip them.
Fab, thanks for the clarification I thought so, but all this electrical give me the jitters. Especially after all the stories of hidden transformers and the fireworks show. I'll snip them and throw a bit of poly filler at the hole.
You're welcome. All the 'discussion' you've seen has been well-intentioned, but, I suspect, really not very helpful to you.Fab, thanks for the clarification I thought so, but all this electrical give me the jitters. Especially after all the stories of hidden transformers and the fireworks show. I'll snip them and throw a bit of poly filler at the hole.
Shall we just say i found it interesting, and leave it at that
In any case, I got my answer in the end, and I appreciated all the comments.
