Hello
I recently moved home and found that the previous owner (an electrician) had installed some power sockets in the loft, however the sockets have no power. The sockets are connected to a 2-way Distribution Board with MCBs, which has the main feeder cable for the board hanging out of the bottom of it. There is also a seperate working plug socket in the loft, which is connected to the main consumer unit downstairs.
So... I was wondering (pretty sure I know the answer though!) would it be possible to connect the Distribution Board's main feeder cable to the existing working sockets supply via a junction box? If not, then could someone please advise me on where I should connect the main feeder cable to?
Thank you kindly.
Thank you kindly.
