Hi there having been reading up on my regs i have realised that we may have a small issue with the towel rail in our Bathroom.
The rail itself is located in Zone 2 in the bathroom with an ipx4 heated element. This is connected with flex to a flex outlet plate which joins it with 2.5TE which goes to a 3AMP switched FCU on the otherside of the bathroom door in the hall.
From what i understand all electrical parts in zone 2 should be ipx4 and this is where the flex plate falls down.
This is the flex plate in question https://www.mkelectric.com/en-ar/Pr...plus/flexoutletfrontplate/Pages/K1090WHI.aspx and in the technical PDF it says:
IP rating:
With flex outlet: IP2XD
Without flex outlet: IP4X
The plate is aprox 40cm from the bath at the moment.
Does anyone know of any IPX4 flexplates or would a simpler option be to have the plate shifted 25cm away from the bath and thus out of zone 2?
IP rating:
