Hi guys, Im going to be installing a twin impellor, 2.0 bar positive head shower pump to supply 2 showers. A couple of queries i have if anyone can help me please?
Which is the best manufacturer of pump? ive heard some horror stories with salamander!
The recommendation is to have a minimum of an 80 gallon tank. Their is currently a 20 gallon tank in situ. I was thinking of installing another tank next to the existing to make up the difference and connecting the two together with 28mm pipework. I have a problem where I will not be able to get a 60 gallon tank up in the loft.
Would it be possible to have a smaller tank connected to the existing tank in 28mm and have both tanks fitted with float valves? would this make up the difference do you think?. The maximum flow rate of the pump will be 18 litres per minute. The cold supply for the showers will be from the tanks also.
