Yes.
I probably should. To be honest, I never did much domestic, I was more involved with industrial, and it's been years since I really did any at all.Only ever once seen 3 phase in a domestic property.
You should get out more then…. there are lots out there. Not in your regular bungalow, I grant you, but lots.
I presume that, since his comments were directed at the OP, plugwash was talking "man in the street" language, rather than electrician language. Whilst I cannot deny that it is the correct electrical terminology, to call a neutral conductor "live" will probably confuse the majority of members of the public, and certainly would not represent 'effective communication' with most of them.Generally there are four as a neutral is distributed.In a three phase system there are three live conductors
As I said, I've got that, probably for the historical reasons I described. In fact, the size of my house is such that it could easily be configured as three flats ('flats' can be small these days!) - and if it were, I imagine that no-one would bat an eyelid at a 3-phase supply to the building, with one phase distributed to each flat.I was thinking more of 3 phase actually distributed into a property though for whatever reason. Only seen that the once, unless you count places with 3 phase feeds to workshops etc.
Mostly I was just being sloppy, it would have been better if I had said "phase conductor".I presume that, since his comments were directed at the OP, plugwash was talking "man in the street" language, rather than electrician language.
Though it gets even more complex, apparently the convention is to consider a plain neutral as a live condutor but not to consider a PEN conductor as a live conductor.Whilst I cannot deny that it is the correct electrical terminology, to call a neutral conductor "live" will probably confuse the majority of members of the public, and certainly would not represent 'effective communication' with most of them.
Which is totally daft as the neutral in the UK is connected to earth any way so cannot be live
Maybe - but if you'd said 'phase conductor' there's a fair chance that the OP, just like most of the general public, wouldn't have had a clue what you were talking about - so maybe 'sloppy' is preferable if one wants 'effective communication' with non-electricians!Mostly I was just being sloppy, it would have been better if I had said "phase conductor".I presume that, since his comments were directed at the OP, plugwash was talking "man in the street" language, rather than electrician language.
I didn't know that - which simply makes it (IMO) 'worse' When not in the presence of electricians, even if I were talking to intelligent people with high-level scientific or related educations, I would never dream of talking of 'line' or 'phase' conductors', and nor would I dream of describing a neutral one as 'live'. The great majority of ordinary people recognise 'live' and 'neutral' - and anything which moves away from that will simply confuse many (potentially even dangerously in some situations). BAS would undoubtedly like the entire population to be 'educated in the proper use of terminology'!Though it gets even more complex, apparently the convention is to consider a plain neutral as a live conductor but not to consider a PEN conductor as a live conductor.Whilst I cannot deny that it is the correct electrical terminology, to call a neutral conductor "live" will probably confuse the majority of members of the public, and certainly would not represent 'effective communication' with most of them.
That is correct.Though it gets even more complex, apparently the convention is to consider a plain neutral as a live condutor but not to consider a PEN conductor as a live conductor.
If it couldn't be live then it wouldn't carry any current in ordinary circumstances. (Ignoring the fact that in a balanced three-phase system it will carry no current.)Which is totally daft as the neutral in the UK is connected to earth any way so cannot be live
Ironically, despite his insistence that correct terminology should be used, he is one of the greatest serial offenders for abusing the term "live" and using it in a completely incorrect context.BAS would undoubtedly like the entire population to be 'educated in the proper use of terminology'!
Because that is the definition of a live conductor, although by convention it excludes a PEN conductor.How can it be classed as live just because it carries current
