Certification of work
30 Aug 2010
London
I am having a single story extension done in my house and my builder brought an electrician to rewire the house and give a certificate. The electrician finished first fix and installed a builders supply. Unfortunately, i entered a dispute with a builder who is in breech of contract for demanding extra payments without discussion or prior agreement. The money that has already been paid to my builders covers the electrician fee.
I was told by an NICEIC approved electrician that by law an electrician can not decline to give a certificate for work he has done. I would be grateful if you could let me know whether i am entitled to request the certificate for the builders supply and the first fix done by my builder's electrician and what i can do if the electrician declines to give it. Thanks
Have you anything connected to builders supply or is it dedicated for the builders? And as sofar as certifying the 1st fix, there's nothing to certify as yet so no certificate to supply
I've got nothing connected to the builders supply. It's dedicated for the builders. The electrician did a certificate for the builders supply but didn't give it to me. Is he breaking any rules?
No. The builder is the client in this case. As the installation is on your property you could require the builder to provide you a copy of the certificate for your records. However given the temporary nature of the installation, most smaller and domestic clients would not bother.
I assume that the work is continuing with another builder & electrician?
I assume that the "builders supply" is still in place and it is now your property?
If so, you could have the new electrician reinstall the builders supply and give you a cert for it, if you really feel you need one. But as Adam says
He has to give certificates for work completed, but since not complete then no he will not have to issue a certificate, although called a compliance certificate when issued by a scheme provider it is actually called a completion certificate when issued by the LABC.
The same happened to me well my son shouted at the builder for not completing on time which for our job was really important as needed to be complete before my mother left hospital, and they walked off site. I then approached the LABC to ask what was required to take over the job, at which point I found the builders had failed to inform the LABC that the work was to be done. Lucky for me is was for my mothers disability so there were no charges.
However you may be in the same position. You will clearly need to inform the LABC that some one else is going to be doing the work, and you can either get an electrician who is willing to take over the electrical work and issue a compliance certificate for whole job. Or if you can't find an electrician willing to sign off some one else's work then it needs to be done through the LABC and a triple signature installation certificate is used where in theroy the new electrician signs for what he has done and the old one signs for what he has done. In my case the certificate was endorsed with limitations and the design signature was left blank, it seems the LABC was only really interested in the inspection and testing signature and issued a completion certificate on the strength of that. They also it seems did some thing which resulted in the builder to stop trading. Which in turn resulted in us not being able to get any money back.
You need a completion certificate from the council, and any electrician will realise that, this is for the building work not the electrical work, however it does mean the council is involved so there could be a problem if the electrician does not do things by the book, in the main the council have there favourite electricians, I know they shouldn't but in real life they do, these are people they trust so they are not worried about signing off work they have done. It may be helpful to talk to council first and see what they say. It is not as if you can not tell them, the building is already started so they will already be involved.
The compliance or completion certificate are legally required. The installation certificate is not legally required, but in real terms it is required in order to get one of the legal documents. A scheme member electrician signs a legally binding document with his scheme provider to say he will follow the requirements of BS 7671 which in turn requires he issues either a minor works certificate or an installation certificate for all work COMPLETED but this is with his scheme provider not you so only the scheme provider could take him to court for not issuing one.
With a installation certificate the three signatures are for design, installation and inspection and testing, what could be in depute is who signs for installation as the electrician one has installed the cables, but electrician two will install the sockets etc. Much will depend on the stage of the other building work, if you need another builder to complete it then that builder may have an electrician he uses and he may do all the work required to keep the LABC sweet.
We were rather dismayed when we involved the LABC who in no uncertain terms told us it was the owners responsibility to inform them of any work being undertaken and although builders would normally do it for the owners it was still up to the owners to see it was done. If the electrician either with sign writing on the van, or advert in papers or any other means lets it be known they are scheme members then the responsibility shifts for electrical work to the electrical firm to inform the LABC through the scheme provider when work is complete.
The builder has walked off the job and the electrician who works for him has made it clear that he isn't coming back without the builder say so. Getting the electrician to sign off what he has done is not going to happen so i am wondering what my options are in the case.
Who did he give it to then?
You will clearly need to inform the LABC that some one else is going to be doing the work, and you can either get an electrician who is willing to take over the electrical work and issue a compliance certificate for whole job. Or if you can't find an electrician willing to sign off some one else's work then it needs to be done through the LABC and a triple signature installation certificate is used where in theory the new electrician signs for what he has done and the old one signs for what he has done. In my case the certificate was endorsed with limitations and the design signature was left blank, it seems the LABC was only really interested in the inspection and testing signature and issued a completion certificate on the strength of that. They also it seems did some thing which resulted in the builder to stop trading. Which in turn resulted in us not being able to get any money back.
What is LABC, is that the council building control officer?
The electrician who did the initial work work has made it clear that he is not coming back as long as the builder who walked off the project is not coming back. He didn't give me the builders supply test certificate which to me indicates that she wont sign off anything.
I used London Building Control which are a private firm rather than the council's BCO. I guess i need to speak to my BCO who has been reasonable so fat, would you say?
The builder brought the electrician in. I havent been able to find out whether he is registered with a scheme at all...
Presumably his Client, i.e. the Builder as is the correct procedure.
Possibly, the builder who walked of the project. I'm beginning to see that this isn't going to be easy to resolve
Why are you chasing a certificate for site temps on this project? As it is going to be ripped out at the end of the job no one is going to really care once it is complete
Normally the only time anyone is interested in the site temps cert is if either the main contractor, or their client who owns the site has a switched on H&S Dept. Certainly had it quite often where site temps are being ripped out and I've still got hold of the certificate for installing them!
Your main concern will be to find an electrician who is prepared to accept and certify the work that has been done so far as his own = the existing design and installation (aka first fix).
That person will have to do this so that he/she can complete and certify the whole installation.
Agree entirely. I think you have enough to worry about with sorting out replacement builders etc. and getting the project moving again without also worrying about a piece of paper for a temporary supply that nobody is really going to care about.
