Hi
I am changing an old gold dimmer switch for a more modern brushed steel dimmer switch but am confused with the wiring i've found. Both dimmers are push on/off and twist to dim. There is only 1 single dimmer switch controlling the light. Can you help?
I found the following (pics attached): -
red connected to L1
black connected to C
yellow / green (earth?) connected to L2
As this is a replacement only the instructions tell me to wire the same way as found except earth as per instructions. The earth connection to L2 is confusing me
Can anyone advise?
thanks
red connected to L1
Can anyone advise?
thanks
