have not adopted or retained them but persist with a plate heat exchanger
Patents are a bugger like that I suppose
But some good lectures came out of the farce with some buffoons slapped down and spanked big time.Well it's drifted into farce but perhaps a question to be answered might be why other manufacturers, some having marketed dual pass heat exchangers in the past, in a very competitive market have not adopted or retained them but persist with a plate heat exchanger.
Bernard, the Intergas appears to be `dual pass single circuit`on the CH side. The 1" looking pipe coils in and out of the heat exchanger a number of times. I would say the Intergas is "dual circuit multi-pass." on the CH and single circuit single pass on the hot water. A hybrid.If it is to be answered can we define terminology first.
The way I see it both Intergas ( separate tubes ) and Ferroli ( tube in a tube ) are dual circuit , single pass heat exchangers.
They can also promote creativity in devising a product that provides the required function without infringing patents. Some outstanding advances have come from that type of situation.This is why patents should only last 5 years. They hold back advancement.
I may be wrong but from school chemistry I recall heating water with the exhanger temperature below 100°C does not create much if any scale on the surface between heat source and the water being heated. Where the heat source is above 100°C the interface layer of water between heat source and the bulk of the water will produce scale. The extremely thin layer in contact with the heat source boils and the scale comes out of solution but the steam is immediately condensed back to water by the bulk of water. This creates a slight noise while the evaoparing layer is very thin with cold bulk water. As the bulk of water heats up and is thus less effective at condensing the steam the evaporating layer becomes thicker and the noise increases. Eventually the bulk water is too hot to condense the steam and the water is boiling and steam is ejected from surface of the bulk water. ( kettle is now boiling, time for tea )I can't see why makers like Ferroli and Intergas do not build-in de-scaling connections into their combis.
Disagree slightlyI would say the Intergas is "dual circuit multi-pass." on the CH and single circuit single pass on the hot water. A hybrid.
a slight noise while the evaporating layer is very thin
Kettling is when the evaporating layer is thick enough to produce more water vapour than adjacent water can condense. The excess vapour has to escape and reach some point in the system where the water is cool enough to condense the steam / vapour back to water .Bernard this known as `kettling`
Yep still available today:Note to Steelmason
Look up the Teknigas G800 series of valves.
Intergas and I assume Ferroli have the same initial hot water draw-off problem. It can be got over by installing a blending valve on the DHW outlet. Few manufacturers make their own heat exchangers. Giaonnni and AIC make a lot of them. If a maker can make its own heat exchanger that does CH & hot water they can cut down on components making the boiler cheap to make.combi with a plate may be cheaper to manufacture
intergas combi can also be used as a water heater only i.e not connected to a primary circuit , hence the need to have a heat exc that can with stand dry firing
Gloworm made a non plate afaik there was an issue with an intial sting of very hot water which could occur when a hot tap was opened
after the heating had been on for a while ? afaik there were some complaints.
Which required a re-work or alteration ??
