Yes that's the one pull that clip off which will leave the switch hanging connected , turn your boiler on with tap running and stick a screwdriver in the hole in the plastic box and tell me what the boiler does
So does the full name of boiler ?They say a picture says a thousand words so that is what my boiler looks like
if thats the boiler,have a look at page 16 figure 30Yes that’s the one , I’ve downloaded the same one
So Not the diaphragm then try buying a switch instead and u don't have to strip boiler parts eitherJust took micro switch off turned on hot tap , pushed screwdriver into switch and nothing ? So could this be the fault ?
Is that still the caseThanks but I wanted help not sarcasm so if you can’t give me any constructive information then keep your opinions to yourself
