- Joined
- 24 Nov 2004
- Messages
- 429
- Reaction score
- 4
- Country
What's wrong with this - if anything? (it is a domestic consumer unit, wired up controlling 24VDC circuits. the breakers are in the Batt positive (+24VDC) line, with the Batt negative (0VDC) line applied to the Neutral busbar.
The red DP breaker breaks both incoming poles, the rest of the MCBs are of course single pole only.
This is on a small fishing vessel on the UK small ships register.
Very many small boats in this general class are wired-up like this, ie using a domestic fusebox as a DC distribution centre.
my general thoughts are, simply from practical experience, that:
these CU's provide an inexpensive and reasonably reliable way of disconnecting the circuits, for technical convenience.
The rating on the MCB should not be relied upon when used in ELV DC operation, because we are no longer on the curve from which the ratings derive, therefore any circuit should be protected with some other overcurrent disconnector appropriate to the nature of the cct.
Notwithstanding the above, these mains-rated MCB's usually *do* seem to operate correctly in fault (overcurrent - normally dead short) conditions in use on ELV DC circuits.
Therefore - in practice, they are OK.
The attached photo was from an installation by a professional and reputable marine electrician in UK.
it has long been a quest of mine to find a rule book regarding ELV and LV wiring for this type of installation. something like the on-site guide ideally. I don't even know whether there is a BS that applies to (coastal) fishing vessels.
IET no use whatsoever. I honestly don't know why I pay my subscription. Vanity I think.
