A career of just over 50 years in electronics. Design of systems, hardware and software for various industries. Major employments were in radio communication systems ( 12 years ) food processing equipment ( 9 years ) and then 20 years self employed designer and consultant. Also self built a post and beam timber framed house, total DIY except for the slates on the roof and the brick chimney stack.
More accurately electronics design and the application of the electronic system which required accurate knowledge of the situation / process / equipment where the electronics were used. Some of my experience with boilers was accrued in the design of an overlay monitoring system for systems using water at 120°C ( 6 bar pressure ). The system collected and recorded data to enable the precise identification of the cause of any failures in the system. A sort of "black box "
