I fitted a 760 shower tray that went under each side of the wall, leaving the opening for the door 725mm.
I had a 760mm door that said it adjusted down to 724mm......
However the actual door and frame, with the channels tight was 760mm..... aonwould only be able to be adjusted wider.
Shop is adamant it adjusts down. When I look at other 760mm doors they say they adjust down.... but don’t want to buy one and they dont
