I want to run some ethernet cables through my house but I am struggling to find the best way.
The house doesn't have flooring or carpet installed at the moment but everything else has been done. It is also does not have a loft (first floor is roof space with dormers at the front).
The flooring on the first floor is screwed in so I assumed it would be just a case of running the cables that way. Unfortuately, it is tongue and groove and also the stud walls on the first floor are built on top of the flooring (which I gather is common these days).
I bought a cavity master but I am worried I'll end with holes everywhere - Also if I have to go across joists then it's not going to be much help..
I also want to run some cables to the soffits for the CCTV - I thought I'd be able to go between the knee walls and soffits but the "knee walls" on the first floor are rather odd as well - I assumed these would be stud work with interior plasterboard, but it seems there is extra wood behind the wall so it's difficult to see in the roof space behind the wall.
I also have an extra coaxial cable in the house which I assume was for an aerial but I can't find where it terminates!
I guess what I'm really asking is - Is there any other things out there that would help me run / trace cables without causing too much destruction?
