Shed cladding - stop nail rust
4 Dec 2003
Hi there. I've just had to replace some of the cladding on my shed. Nailed the boards on and I need to get them protected asap. I coated (x3) the boards with preservative, but I want to make sure the nails don't rust through onto the paint as I've had before. What do I use on the nails? I've read oil based paint/exterior caulk/knotting solution.....what can anyone recommend?
Many thanks!
bit late now
round here (coastal) we use stainless. Roofers formerly used bronze.
I hope you used, at least, galvanised nails?
What about a rust killing metal primer?
I'll have a look for one, many thanks
bit late now
Hi, nope, fraid not. The rest of the shed (80% of the shed) wasn't put together with stainless/galvanised and I'll have to treat all the nail heads before painting it - the shed was stained previously. I painted another shed of mine and it seems that when you paint them with a water-based paint it's that which causes the reaction and rust. Or maybe with a dark wood stain, you just don't see the rust trails down the shed, but when you've painted it a light colour you certainly do. At the moment I'm leaning towards cleaning and sanding the whole shed, then sinking the nails below the surface where necessary and then using some decent exterior caulk before priming and painting. I just wondered what the "standard" way to do it would be. But maybe I'll use a rust killing metal primer.....
