- Joined
- 24 Oct 2021
- Messages
- 3
- Reaction score
- 0
- Country
Hi guys, I am thinking of adding a new radiator in our kitchen but, although i'm quite generally handy I would like to know the correct way of doing this as in theory it would be tapping into the boiler CH output an making the radiator i fit the first in the system.
As im sure you are all aware the output pipes are 22mm but a radiator is 15mm, is it really as simple as cutting into the pipe, running 22mm pipe to the radiator ( with a 15mm reducer to connect up ), same coming out (15mm to 22mm ) then connecting back to where i cut in ?
