Hi all.
Having problems with my garage boiler flue leaking. Had problems with my garage roof leaking when I moved in, managed to sort them with cement sides and fitted a dry ridge myself.
The boiler flue goes straight up from my boiler out the top of the roof. It's badly fitted due to the lead flashing is split and the cowboys that fitted it, I noticed water dribbling down onto the boiler itself a whole back. I tried to repair this temporarily by using roofing and gutter sealant which seems to have done fairly well actually.
The tile ontop isnt sitting exactly flush with the rest, I haven't managed to get a lend of a grinder to cut this yet but thought it wasn't too far off where it needs to be. Following a video online by fixmyroof I took the tiles off and tried to see if there was anything obvious I could notice why it might be leaking and nothing apart from the flashing had sagged at the back so I straightened it up and put a piece of batten in to hold it there and a little cement to try and stop water running backwards hoped that might be it sorted as my fear was the water was running down the back of it and into the felt and thus into the flue.
Today its raining and still leaking so I've gone up to take a few snaps for you guys see if you can see what's causing the issue.
It's not torrential just an odd drop here and there, if I shine a torch up inside the felt underneath I can see its wet. Obviously this collar needs replaced but I don't want to do it until the summer time. I understand its a little hard to see up inside apologies.
I was going to replace it with this and just mold it to the tile again but would like to repair it for now. - https://www.screwfix.com/p/floplast...JCexXGw5sIOvN3k2rgsaArfNEALw_wcB&gclsrc=aw.ds
Any comments or advice welcome thank you.
Edit - Just been out to check inside again as the rain is quite heavy and seems to be slightly worse than I thought. The water SEEMS to be coming down the side facing the block wall so from the aerial point of view it would be facing away from the roof.
Can't understand where the water is coming from
