Shared external stop tap is underwater
7 Jul 2020
We've a tiny leak on our internal stop tap on the supply side after bumping it while doing renovations, i was going to change the compression olive by turning off the supply in the street to work on it but it seems the outside tap is underwater (attached picture).
I believe this supplies three properties. We're in a 1900s terrace and there's one of these every 3 houses on the pavement. I had a look in some other covers down the street and they're dry. The water in ours looks pretty stagnant so i don't think it's a leak? It could maybe be ground water? I'm wondering what the protocol is here? Is it pretty common for them to be filled with water? Should i ring the water board?
Yes, that is what my neighbour had to do in a similar situation.
Yes it's common. Bail it out if you're curious, otherwise phone local water transporter- they'll have a Leak Line somewhere :) .
It may well be rainwater.
Bale it out with a ladle, a small bucket, or a wet-and-dry vacuum cleaner if you are lucky enough to have one. I have also used a child's supersoaker water gun. Even a Turkey baster will do it.
If you are very keen, use a garden trowel to get the mud and grit out so it is nice and clean down there.
Rubber gloves would be a good idea. You may cut or graze your hand and the water may be very unhygienic.
A stopcock key can be very useful. This one fits several sizes.
https://www.screwfix.com/p/rothenberger-universal-stopcock-key-920mm/71652
Thanks for the responses, the wet-vac is a great idea, I'll give that a shot, hoovering the inspection plate on the pavement will give the neighbors another thing to curtain twitch over!
I'll keep an eye on it once it's dry, see how long it takes to fill up again, but glad it's nothing serious.
I like to keep mine clean and clear
And the big one
The key fits several sizes
That stopvalve may well be of the Hex key type, they come supplied with a wire rod, with hex end and Triangular handle to turn it. Usually a 10mm Hex Key, replacements for the original don't seem to be available for some reason.
how badly bumped, would nipping up the compression fixing a bit stop the leak?
i was told some years ago, by a plumber , when he needed to turn off our outside tap, that if he did it and the tap broke, i would have to pay for the repair, if i called waterboard out - and it broke, they would fix, they came out, it broke, 3 days to fix .....
not sure how true the payment situation is
Yes, it does look like that. Presumably a socket set with T handle and extension bar would do it.
I used to have a water meter with the push-on plastic handle.
External Stop Tap is usually Water Co's responsibility, round here Anglian have changed/fitted them in the past FOC when there was/is no other way of isolating the supply into a property.
