Socket under sink
16 Jan 2012
Uk
My daughter just texted to say that she has just noticed a plug and socket under the sink , for the dishwasher.
This is a brand new house. I told her it may seem a little strange but is probably within the regs.
Can you confirm it is still allowable, please?
I was on a job where fuse box was under sink. Makes no sense.
It's permitted but IMO undesirable.
I'd consider swapping it for a weatherproof "outdoor" one with the cable entering from underneath and a lid that will shut with a plug in it.
Why is everyone getting concerned?
would you have the same questions if it's in the cupboard adjacent to the sink?
Or on any downstairs wall when there are pipes in the ceiling? And yes, I've had a leak upstairs run into a conduit and come out inside a socket back-box downstairs.
Me too, fortunately at work in the workshop, not at home.
Also at work on a customers site an emergency stop button for a rooftop chiller mounted above the contactor which was mounted above the isolator with conduit couplings. Conduit from bottom of isolator through wall to bottom of horizontal trunking which turned a corner and dropped several floors then into horizontal trunking and then with big brass bushes ~4" and couplings into top of control panel, where the water ran down the wires to the internal slotted trunking and dispersed into the top a row of MCBs, the insides of one had rotted and failed (for a completely different circuit).
Seeing the water damage I insulation tested and found a problem on the chiller wiring and hence the contactor, it was easy to trace the water marks in the salty atmosphere.
My instruction for repair: replace the faulty MCB and contactor, when I returned with parts I found a hood around the E stop fashioned from an ice cream container.
A lot of hysteria in the world about electrics under kitchen sinks.
Yet it's ceiling lights and pull switches that get soaked when there's a leak...
