I have a Neo-Angle shower tray, … imagine an oblong with corner cut at 45 degree It’s 1.2m x 0.9m (pic only shows a small tray)
(see pic)
The ‘Roman’ shower door has failed, the only shower door that fits this tray is a now a ‘Roman’ glass frameless style. Ordered it and I have hit a problem
Installation is by fixing the vertical channels to the wall and you slide in the 2 glass panels (they have bonded on ends that slot into wall channel)
Then you fit a door opening bottom bar (fixed size) and slide panel ‘out of the channel' until tight on this bar .. and then fix everything up,
(see pic )
The issue is the enclosure assumes the edge of tray is tight against the wall .. and then wall is tiled on top … effectively moving wall in another 10mm or so over the tray edge
My shower room has no tiles the wall is boarded floor to ceiling with Respatex shower panels. The shower tray pressed tight up against the panels, but the tray (due to the way it is manufactured) slopes in so the top is set forward by aprox 10mm. (marked in Red on sketch attached)
(see pic 2.)
This means that when I try to fit the glass panels they are almost coming out of the wall profile, and could not be fixed. They have only small adjustment.
This is the way room has been finished … I know fitting tray first then panelling would have been option, but the Respatex dealer advised against that.
I can't just fit glass panels further back as the glass ends of panels have to fit snug to the centre spacer bar, as this sets the door, seals, hinges etc. The manufacturer does not offer a deeper wall profile or a spacer.
I could resolve by fitting a spacer bar between wall profile & the wall … would need to about 20mm thick and as the wall profile is 1.25” wide, at least the width of that. Height around 2.0m
Anybody have a suggestion for a spacer, that would be unobtrusive (within reason) and waterproof
Alternatively, I would have to take the tray out and cut the wall to inset the tray, as it’s all plumbed in and sealed …. A damn big job.
(see pic)
(see pic )
(see pic 2.)
