If you can take a photo of that (and the wiring connected to it), we may be able to advise further.there is some other thermostat in the corridor
It is very common for the existing thermostat to be replaced with a 'smart thermostat', or similar. In which case, all the timing functions are taken over by this.isnt easier to just replace it on the actual boiler or is more likely to break again due to the clockwork pieces etc.
If you wanted to do that you could only use an exact replacement for the one you already have, would be the easist way to do it, its called a worcester MT10, around the £60 mark Mr Central heating is probably the cheapestthey were sposed to give me a quote for a non wireless too i thought. isnt easier to just replace it on the actual boiler or is more likely to break again due to the clockwork pieces etc.
Is a mechanical more likely to mess up in the future again though? Cheers.If you wanted to do that you could only use an exact replacement for the one you already have, would be the easist way to do it, its called a worcester MT10, around the £60 mark Mr Central heating is probably the cheapest
the on board digital ones are far more likely to fail than the mechanical one, if your existing boss is wired then just replace it with a programmable room stat and leave the existing clock set to constantly onThe current thermostat is working completely fine, but maybe a direct replacement of the mechanical timer is still more likely than a wireless unit to fail in a few years again? Im probably overthinking innit.
The eph programmable one is an on board digital? Ive no idea. I think ill get charged more to both do something with the boss and change the mechanical timer with another.the on board digital ones are far more likely to fail than the mechanical one, if your existing boss is wired then just replace it with a programmable room stat and leave the existing clock set to constantly on
do you have a link for this ?The eph programmable one is an on board digital?
you dont need to change both just swap the boss for a programmable one, and leave the existing timer set to on.think ill get charged more to both do something with the boss and change the mechanical timer with another.
Just says it's a programmable eph room thermostat in the quote, theres no link in itdo you have a link for this ?
What exactly is the problem with the existing timer ?
Every day is a school day, never seen an EPH that would replace that on board mechanical timer with an on board programmable room stat, think you may be getting confused and they are actually going to install the EPH receiver outside the boiler, and set the existing to constantly onJust says it's a programmable eph room thermostat in the quote, theres no link in it
yes you can do that, if it was me doing the job I would simply swap the existing Boss for a programmable room stat, you could do it yourself very eay to dook, so just to confirm. Instead of any wireless soultions, just replacing part for part the mechnical timer will give me greater lonegivty? (on average) Thanks.
but its wired, I'd be scared shietless to deal with electrics as a layman.yes you can do that, if it was me doing the job I would simply swap the existing Boss for a programmable room stat, you could do it yourself very eay to do
