- Joined
- 13 Mar 2019
- Messages
- 707
- Reaction score
- 171
- Country
What in the one room are you heating? I heat myself in my home office with a heated blanket - 40W max.
I know gas is cheaper but am not going to turn off 15 rads at night and 15 rads on next day every time. They are balanced rads so hassle and possible mistakes.
I am comparing 22KW boiler to heat 16 rads when one room is used against a 1KW electric heater. 1KW electric heater will cost max 34p/hr and boiler will cost over £1/hr, with today capped prices.
Anyways, after further consideration, my choice is wall mounted oil rad.
I have theseI know gas is cheaper but am not going to turn off 15 rads at night and 15 rads on next day every time. They are balanced rads so hassle and possible mistakes.
It entirely depends on the circumstances. I sit at my desk most of the day, and cool down as I am not particularly active. When I'm in other parts of the house, I am moving around, so don't feel the need for heating. Other seasons and combinations of people in the house require other combinations of central and local heating, as appropriate.It has already been said, an electric blanket could keep one warm, but why bother even with an electric blanket, just a blanket would do the same, but the whole idea of central heating is we can get up and walk from room to room without wearing out door cloths
What do you read into this:
Do panel heaters use a lot of electricity?
Panel heaters are less efficient than electric radiators because convected heat is inherently less efficient than radiated heat. This means that you'll need to use more power to heat your room with panel heaters than you would with energy efficient electric radiators.
Well, almostAll direct electric heating system are 100% efficient, no more, no less.
Well, almost
A few of these ceramic rads are also marketed as 'smart' - having LCDisplays and WiFi - so you may lose a fraction of a watt on radio waves and light!
Yes, the energy will eventually end up as heat - however, unless fully absorbed, it will not necessarily end up as heat inside the room...The 'fraction of a watt' will end up as heat, so still 100% efficient.
Define efficient. To my mind to heat a room to the temperature required for occupancy unless the room is used 24/7 one takes a ratio of time being heated compared with time being used, so heat for two hours and used for one hour then 50% efficiency.Absolute, total lies... All direct electric heating system are 100% efficient, no more, no less. The only exception are ASHP systems, which exceed 100%
If you need to "heat" just one bedroom (independently of any other domestic heating), the best device is a "Fan Heater"- with this type of design, with a thermostat.Q. Occasionally, I need to heat one bedroom in my house before sleep when alone. I have 16 rads, gas boiler 25KW boiler, surely 1KW (or less) electric heater is more economical than CH. Which type of electric heater shall I buy?
