Log Burner on Floating Wood Floor
Okay that’s makes sense. Thanks very much. It’s a 1970s house and the concrete foundations seem really solid and no signs of subsidence so I’m guessing the solid concrete base might be overkill.
Thanks again. That’s really helpful.
Sorry, just re-read your original & subsequent posts and I am now under the impression you are going to build a brick or block chimney breast, 3+ meter high, in which you will insert the log burner on top of an existing floor of T & G boards or chipboard. If that is the case then I agree with the first guy that you need a cast concrete base underneath it.
There’s nothing there currently and we’re building a tall chimney breast to house it.
Built a faux fireplace at my previous home, fire board above brickwork and then plastered.Used yorkstone for hearth.
If you are building a proper fireplace then yes, you will need the right foundation under it
We may need to reconsider the construction to lighten the load a bit but either way it’s going to be a lot of weight in one area so it needs some decent support. Thanks.
Totally agreed. Thats why I was asking for advice on which method was best from the options we’ve been given.
