Hive Thermostat wont turn on boiler
14 Sep 2023
Greetings all.
I recently installed a hive thermostat, hub and receiver however, when changing the temperature the boiler just shows Status 0.
It's an Ideal instinct boiler, the hot water works absolutely fine. The receiver shows that it's communicating with the hub and thermostat but just won't seem to communicate with the boiler
I have attached photos with wiring and front of the boiler.
Many Thanks
Assuming you have a single channel Hive; move the black wire from terminal 2 into terminal 1.
Greetings all.
Many Thanks
Wired wrong. You need the common from the boiler going to the common terminal nothing should be in heating off.
