Is it worth getting a smart meter put in the house by energy company ?
Bear in mind they are being introduced by order of the government; not the energy companies.Is it worth getting a smart meter put in the house by energy company ?
This is the point, before the smart meters there were systems to auto read what power was being used, and the bills were corrected once a year, my bill was within £10 so for a single tariff they have no advantage at all. However the law it seems has been changed, not sure who made the rules, but it seems no longer can energy companies use the meters installed when solar panels are fitted to pay you for any feed in power, and the radio 4 time signal for setting duel tariff meters is being withdrawn, so old economy 7 meters will have no auto correct to the time, so we are being forced to fit smart meters if we want to be paid for feed in power or have multi tariffs as now being used with EV charging.On it's own - no.
If you intend to make use of things such as time-of-use tariffs, or have solar & battery systems then it can be.
It would be interesting to see a survey of percentages of say Electricians, Electrical Engineers/consultants etc that have smart meters by choice against those who choose not to
Today is 14p per unit, instead of the standard 27p per unit. If I'd joined a year ago I'd have saved many £100s. Past performance is not an accurate guide to the future!
No. Avoid at all costs
This will prevent subsequent governments proceeding with charging you more per kWh at peak times
Which they have had the ability to do, for many decades..
And to automate we need some automated signal as to when price goes higher or lower. I have same with heating, I can view the TRV current and target temperatures, and start and stop boiler all from the PC, but I can't link them together in an automated way so boiler only runs when target exceeds current on the TRV, any interconnect has to be manually made.
You use battery storage, such as the one you had installed recently.The problem is how can we select when we use power?
