Sealed Upvc window filling with water.
14 May 2007
Hi, Can anyone help please? 3 of my upvc window are filling with water which is rusting the handles and presumably mechanism, from inside the bottom rail (the water is in the part surrounding the glass and filling the bottom rail if that's the right word). The window surround seems sealed with no drainage holes on bottom, top or sides. The actual window frame has drainage holes and seems fine. I don't know how the water is getting in. How can I solve this? Can I drill holes into the window surround? Would have to be sides as bottom seems to be taken up by the metal window mechanism.
All 3 are large top opener window with handle at the bottom.
Hi, did you ever figure out where the water was coming from? We have the exact same problem but no one seems to be able to figure it out. Thx.
Again, photos will help.
The two people that I would most hope reply, if i were you, are @ronniecabers and @crank39 - no disrespect to anyone else though.
Sorry I thought the OP @Boycromer might reply as I was hoping they had fixed their issue from 2022. Happy to attach photos and more information.
We have a top hung outer opening double glazed upvc window on the ground floor and gable end of the house. It’s above a fixed pane of glass underneath. I’ve added a photo.
When it rains we get water leaking from the handle of the top hung window as marked in green on the photos. The water runs out of the handle, down the inside bottom pane of glass and pools on the interior window sill.
We contacted a window repair guy who wouldn’t come and take a look as he said it was water getting in the wall cavity above and then in the window, so no issue with the window itself. However, our weep holes are clear above the window and there is no sign of any damaged brickwork etc. Also when it rains and the handle is leaking the part marked in blue on the photo and the frame above is completely dry.
The seal around the outside of the window appears to be intact and the drainage holes on the fixed pane of glass below are clear and working.
All walls around the window on the inside are dry and do not show any signs of damp.
Any ideas on how the water might be getting in the window would be greatly appreciated.
