- Joined
- 13 May 2021
- Messages
- 72
- Reaction score
- 3
- Country
Hi guys, after a bit of help...
Have just wired up my system with a hive and UFH setup with zone valves. All working great thanks to help from everyone here.
The problem I have found is that the system will only fire (when for example hive calls for heat), if the built in timer is plugged into the boiler and set to permanent on.
If I remove the timer from the boiler, unplug it, and try to get the hive to call for heat the boiler won't fire.
I'm not sure if aside from unplugging, I need to do something else....
Boiler is 35cdi combi
Thanks for the help!
Greenstar CDi Classic Combi ErP Installation and Servicing Instructions | Worcester Bosch
central heating boilers, combi boilers, gas boilers, oil boilers, gas central heating, heating engineers, boiler installation, boiler repair
www.worcester-bosch.co.uk
