Junction box/fused spur/socket
19 Aug 2011
Leeds
Hi, quick query, without all the extra info.
I want to add another double socket in a bedroom.
The socket that is in there which would ideally spur’d off is already a spur.
I’ve traced the wiring back to a junction box which also serves another set of sockets I believe to other bedrooms (I’ve to investigate this further)
Is it ok to put a fused spur between the junction box and the sockets?
Ie - JB/2.5 TE/FCU/1.5TE/2 x double socket (bedrooms x2)
Yes, but check the other sockets are not spurs on spurs
Thanks for the reply, I’m a little concerned they are likely to be spurs on spurs from what can make out, but need to trace them properly.
B32
32 amp breaker suggest a ring main, as your cable is 2.5mm2, so one double socket per spur unless protected by a FCU as I understand it.
I don't understand
Ring main was what sparkies referred to ring finals as when I had a rewire 30 plus years ago. I was just making the point about different terminology in a wider context, for example: fuse box, fuse board, consumer units, consumer’s unit etc.
When does a technical description that may not be understood by diyers/ customers become pedantry?
Yes, people are often mistaken and use the wrong words.
How will they ever learn the correct ones if you just repeat their wrong ones?
That doesn't actually make sense. :)
Thanks for all advice so far…
So just for clarity, if this junction box serves other sockets on different 2.5 te wires particularly if it looks to spur from a spur, it would be safe to put in and FCU on each spur wire prior to the first socket?
Is there any disadvantage to dropping to 1.5mm TE for the sockets after the FCU or is it potentially preferable to stick with 2.5TE throughout?
What practical difference does it make whether people say ring main or ring final, both terms are understood or readily explained
One is not correct.
Can you seriously not think of a reason for not using the wrong names of things?
