Any chance the boiler house has been flooded Grill.
Any ideas here my friend??
Oilman,
Have sent this to your email address as well to double my chances of you answering it.
Went back to that Riello and changed the nozzle. No joy. Stuck in a new pump and away she went.
I set up the pump and burner as best i can using my Riello Training manual. 60 80 S nozzle 2.7 on the damper setting etc. See i am trying to do it right. 4% on the FGA. (this figure is wwrong in the email i sent!!!)
All was sweet until the burner had run for a minute and then i had loads of white smoke/steam billowing out from underneath the boiler!!!Probably got a split water jacket,not smoke,its steam ,itsste
Now the ground on the boiler house is wet (bad installation) and there has been a lot of oil split in there over the days.
Im praying this steam from teh ground but it was still coming after teh boiler had run for 10 mins albeit not as much. Could this be a leak in shell??
I took teh top cover off and baffle plates off and looked in for split oil inside. No sign. When i ran teh burner with all this out there was no white smoke/steam.
G
None but why do you keep writing "the" as "teh" ?.
Its really beginning to bug me.
Was called out to a oil boiler there that i serviced 6 mths ago
.See i am trying to do it right
Then he wrote.
Previously he wrote.
And your stepping around in a flood of oil and water and you expect the forum members to believe that you are doing this "right".
Pull teh other one.
The lads already said it something he's done since being young.
Try to type too fast.
Good to see we are all on top form tonight!!!
No dyslexia just totally rubbish typing and i saved teh in the dictionary by accident so it doesn't pick up on it!!! Hope that is that sorted!!!
Well any smoke that i have seen coming out of an oil boiler has usually been black so im assuming its steam but if there is anyway it might be smoke then PLEASE enlighten me.
Believe me i thrive on finding out new info no matter how much abuse i have to take so be cruel to be kind.
I was thinking about the shell problem but how do you tell?
At the risk of getting a **** should i run the boiler until the boiler house had dried out and take it from there??
Body armour on. Unleash the abuse!! Is it a pressurised system?
G
