Eave tiles - necessary or optional?
30 Mar 2005
I have had the fascia of my house replaced and recently my roofer came round and told me that the eave tiles have not been replaced.
The company which replaced the fascia said that eave tiles are not needed as they have weatherproofed the roof by putting in a sealed layer of siliguard (can't find it on tinternet - possibly not spelled correctly).
I have been up to look and can certainly see a vertical layer of black plasticcy material laid under and inset from the bottom layer of roof tiles, leading into the gutter.
The roofer says the eave tiles need to go back.
Both parties have a vested interest in their advice.
Any idea who is correct?
Thanks, in ignorance
CJ
Hello
I also have been having problems with my roof. I was received quite a high quote and was not sure if this was right. I contacted my local roofing merchants and they were very helpful. They advised me on what to do and put me in contact with a reputable contractor. this saved me quite a bit of money. they have a few branches, you may want to give one a call if they are local to you. the web address is www.rightwayroofingsupplies.co.uk
Gary
The eaves tiles are needed to support the first full size course of the tiles and also to stop water getting through the joint of the first full course, no matter what this Silliguard is the eaves tiles should have been put back
What they've put there sound like an underlay support tray and whilst it will take the water dripping through the tiles into the gutter, that's not what it is meant for.
(if you need a reputable roofing contractor go to the National Federation of Roofing Contractors www.nfrc.co.uk)
tell the half-wits to put the eaves tiles back where they belong.
according to their reckoning, you may as well remove all the tiles from the roof provided there is a membrane of some sort beneath.
FFS.:rolleyes:
aboslutely Tell them you want YOUR eaves fitted as they should be.. dont take any BS
Surprise, surprise.
The company involved (named after an eastern county) having chatted with my roofer, now think that eave tiles are a really good idea and are going to put them back at their expense.
Thanks very much for the advice, which made for a good argument.
CJ
