- Joined
- 27 Apr 2008
- Messages
- 9,448
- Reaction score
- 894
- Country
HI, I'm part way through building an internal vestibule in my house, mainly to keep out the noise from the main road.
Am using 12mm plasterboard & kingspan on a framework of 3x2" & its going fine. This whole project is hopefully going to cost me no more than £100 as I have the wood, the door, glass & kingspan already.
However, I'm putting in a window over the top of the door so that any light in the lounge gets into there & vv, I currently have plasterboard either side of the 3x2" rectangle. I am thinking of getting some 3.5"x1/2 nice wood to line it with, plaster upto the edge (tape the front & insode so I dont mess on it) then down the very middle put a bead of 9x21mm to crete a frame for glass to go against, then put silicone along it & fit a piece of 4mm (old coffee table top) glass on one side, with 11mm quadrant beading at the front.
Assuming the glass cuts to size (if not I may just plaster the hole up ).
Because I'm a tight git & I recycle lots I dont want to buy in things like glass.
The wood frame will be painted & there will be architrave around the whole frame.
Can anyone see anything I'm doing wrong suggest what may be better?
Cheers,
Mattylad.
Cheers,
Mattylad.
