For
Labour only.
1. Relocation of shed(and slabs). what size shed, timber or metal, what condition, how is it fixed together, where is it being reloacted to, up any steps, can is be moved whole or will it have to be taken down and reassembled. WHat type of slabs are they, 38 x 450 x 450 or 50 x 600 x 600, how are they fixed down, where are they going, does it need any preperation, how wwill they be fixed down?
2. Build a 54 ft fence x 4ft high. closeboard, panels, closeboard panels, chainlink, decorative panels, security, concrete posts, timber posts, existing fence to be removed, any obstructions in the ground, gravel boards, on a slope or level, any obstructions above ground, wind loading in area, what type of soil is it into, what access for deliveries, what is parking considerations, how far to water and electric, is there any,any issues with neighbour, any issues with planning?
3. Build a 25ft fence x 6ft high. as above?
4. Build a 8x10 ft Decking hardwood, softwood, nailed, screwed, ground level, at height, balustrade, steps, which type of balustrade, any finish to the deck, any issues with existing door cill levels, any manholes, any gulleys, any levelling work to done, what type of ground for the posts, any restrictions on the longest boards i can get in, any pattern for the deck to be laid in, what type of weed suppresion do you want?
5. Laying of 35 450 by 450m slabs on slight slope. what type of slabs, am i supplying, what type of bed do manufacturers recomend, what type of pointing, any gulleys, any manholes to be altered, inlayed, what is there already, how much sub-base will be needed for the type of soil, where can a skip go, will it need a permit, where can cutting be done, where can knocking up of mortar be safely, cleanly and conveniently carried out. can i get a wheelbarrow to it, whats the weight of the slabs, how are they delivered, what pattern will the slabs be laid, is there much cutting to do, is there much setting out to do, any problems with drainage and falls?
6. Removal of grass and levelling (approx 54ft x 25ft) As above
7. Laying of 3 tons of decorative aggregate. As above, but which type of aggregate
What would your estimate roughly be for this work.
