Split Load or not
Whether the OP made a reasonable estimate of the total amount of time involved in all the activities and/or accounted for that time at a reasonable hourly/daily rate, I haven't a clue.
Yes JohnW2, but my question was to the OP and my answer to him sought to explain why there might be a difference between his estimate and the actual one.
To the OP there will never be any consistency in quotes for numerous reasons. Not least because often the price is what the market will bear; different contractors have different overheads and sometimes and lets be frank here you get the vibes from your prospective customer that he is going to be a PIA and you price accordingly.
On the issue of consistency, I am currently getting a quotation for a new conservatory roof - one that has an insulated roof. I have had two quotes and helpfully each quote broke down the cost of having seven down lights and one ceiling light installed. One priced the job at £750 and the other at £500. As for the parts I asked for dimmable JCC FGLED6's which even at trade will cost me nearly £30 each - add the dimmer and the ceiling light gives you parts price of around £270. Each claimed that they were required to have the lighting work 'registered' with the LABC which bumped up the price considerably.
Obviously, that is not correct and will not explain the significant difference in price, so I will be doing that part of the work myself. But maybe its because I'm also a PIA.:p
But this example also perhaps explains one other factor the OP hasn't taken into account and that his builder will be making a profit off your use of his electrician.
OP said:
Quotes from builders to include that by registered electrician vary between split load or not? Do I need or might as well have split load as being replaced anyways?
What is meant, these days, by 'not split load'?
Is it all RCBOs.
Is that the difference in price?
one builder wanted to replace with same style but more ways. Then when other quote mentioned split load i started to wonder if you must have split load hence my question
Indeed - but I only jumped in because you answered cryptically, hence unhelpfully to the OP, by not actually telling him what 'two very important bits' he had missed!
Kind Regards, John
Well, in a way , yes you must.
If your existing CU has all the circuits protected by one RCD then no one would replace it with the same.
Split load means two or more RCDs protecting the circuits.
That's why I am unsure what was meant by 'not split load' these days.
I wondered if they meant all RCBOs - a lot more expensive.
One would hope not.
That's probably what it most often means these days. As you know, originally it invariably meant that about half the circuits were RCD-protected and the other half not ... an arrangement which obviously still persists if RCBOs are used in most of the non-RCD positions.
Although, as above, one would hope that no-one would install a single-RCD (covering all circuits) CU these days, there are plenty still out there to be purchased - even TLC offers a good few. ... so the OP needs to be sure that some joker was not proposing to use one of those!
Kind Regards, John
When pasted in like that does it become impossible to remove?
No - it's just a ordinary part of the text - so can be deleted just like anything else. In what sense it constitutes "Advanced Copying/Pasting" escapes me - it's just a darned nuisance :)
Kind Regards, John
